fender1983@gmail.com
I heard i need to ground spark plugs when doing compression check. Is it true? If yes, how to do this?
Manual from 2001 doesn't say anything about grounding them:
1. Remove spark plugs.
2. Install compression gauge in spark plug hole.
3. Hold throttle plate at W.O.T.
4. Crank engine through at least four compression strokes to obtain highest possible read- ing.
5. Check and record compression of each cylinder. Variation of more than 15 psi (103.5 kPa) between cylinders indicates that lower compression cylinder is in some way defec- tive such as worn or sticking piston rings and/or scored piston and cylinder.
6. Compression check is important because an engine with low or uneven compression cannot be tuned successfully to give peak performance. It is essential, therefore, that improper compression be corrected before proceeding with an engine tune-up.
7. Cylinder scoring: if powerhead shows any indication of overheating, such as discolored or scorched paint, visually inspect cylinders for scoring or other damage as outlined in Section 4: Powerhead."
