I am having to redo the top end in my 96 gsx. The machine shop checked with wesco and they have a 1.5 mm over. So they bored and honed and got the pistons and rings.
I looked in the manual to see if the rave valve should be adjusted and there it said the motor could only be bored one over and that is .25mm
It said the unless you have a min. clearance of .375mm will require reworking the guillotine to achieve proper clearance.
Anybody ever done this. Can you cut the other end instead?
The more I dig the deeper I get
