jimini cricket
I will be naming all the parts from the "Parts Catalogue SEADOO GTX 5640" catalogue number 219 300 230.
This is the way i did it. If anyone has a better way please feel free to add to this. I hope it helps someone.
I want to give credit to a guy called "soccerdad" at this site for helping me out with this. If you need the film, ask soccerdad he might still have some of the film left for sale and much cheaper than in other places. His price? $10 shipped!
Note: It is possible to work on the "infometer center gauge" without having to remove the "deflector" from the "dash board" assembly. However you will have to remove the "dash board" and the "deflector" assembly from the "storage cover upper"
1. Remove the 6 screws from the "storage cover lower" part 269 500 268. This is the Black undercover that it is attached underneath the "storage cover upper" part 269 500 259. There are 6 stainless steel screws, with 6 stainless steel washers and the same number of pressure washers. There are also 2 O-rings on the two bottom screws.
I took 4 screws out and left the two on the bottom loose on the undercover, so as to keep the undercover in place, until i loosened the two screws that held the "base latch" part 269 000 015 at the top in place. Just loosen them enough were the undercover can be pulled from the base latch. Don't remove the "base latch, which secures the cover at the top also. Then take the last two screws out from the bottom of the undercover and pull the undercover out from the latch and set it aside.
2. Underneath of the "storage cover upper" there are several screws of several sizes. Remove the two large screws right under the connector's "mounting plate' part 278 000 852 where the connectors from the gauges and the temp sensor are mounted. I removed the electrical connectors from the "mounting plate" so i could access the screws better.
Note: Above are the bottom screws that attaches the "dash board" to the "storage cover upper" lid. You can also see the "mountain plate" with the screws behind it. The screws are placed back in the "dash board" after i removed them to keep them from getting lost.
3. Remove the three small screws that hold the "deflector" part 269 500 303 to the "storage cover upper" and i think, but not sure that, depending on the color of your ski, this number could be different, mine is green. under the "deflector" is the cluster of gauges (three) Now you will have the "deflector" and the "dash board" part 269 500 355, and the 3 gauges all in one piece together. The "dash board" and the three gauges in it, are going to be connected by two hidden screws to the "deflector" on the top, so don't pull on the "dash board" thinking that is being held by clips to the "deflector" because you will break and damage the "deflector" screw inserts.
Note: On the left are the top screws that attaches the "dash board" to the "deflector" on the top. This is not the "storage cover upper" lid, but the "deflector.
4. Once the "dash board" and the 3 gauges in it are separated from the "deflector, you will see that around the gauges there are two styrofoam pieces. One piece is formed around all three gauges, it is flimsy on the sides and it will come apart so handle with care. If it breaks wait until you are about to put everything back together and then use a bit of "black silicone" and put it back together and wrap a piece of black electrician tape all around it.
the other piece of styrofoam, was square and was around the "infometer center gauge" only. In order to make this easier i removed all the zip ties from all the cable zip tie connectors, loosening all the wires to the gauges.
This allowed me to be able to pull and turn the "deflector" upside down unto the "storage cover upper", place a towel over the "storage cover upper" to avoid scratches and damaging the paint on the "storage cover upper". Now push the styrofoam out of the gauges carefully and unto the cables. You will see the two small screws holding the "deflector" to the "dash board" on the top of the gauges "dash board". Remove those two screws and the "deflector" and the "dash board" will separate. Set aside the "deflector".
5. The "infometer center gauge" is inserted into a large rubber sleeve, "gauge support" part 211 200 018, push the gauge forward out of the rubber sleeve "gauge support".
You will now see the black metal ring around the "infometer center gauge" part 278 000 841. I tried to remove the metal ring without having to cut it and i was not successful and i had to cut the ring.
I used a mini hacksaw. Be very careful and go one stroke at the time because the ring is thin, and underneath the ring is a rubber washer that it is glued to the lens and you do not want to cut into this rubber and definitely not into the lens.
6. Remove the black metal ring from around the gauge once you cut it open carefully and DO NOT DISCARD IT, you will need the ring again. The ring will distort and be possibly damaged if you open it too wide. Do your best to slowly remove the ring from around the lens without spreading it too much, or distorting it too much or creasing it. Set the black metal ring aside for later.
7. After you remove the black ring, pull the lens with the glued rubber ring around it off the face of the gauge. Once you remove the black ring the lens should be sitting on top of the face of the gauge. Set aside.
8. The next step is to pull out the assembly that it's inside the gauge housing to exposed the inner workings of the gauge and I used a flat tipped screwdriver for this.
Insert the flat tip screwdriver between the gauge outer housing and the inside gauge assembly and pull forward the display assembly, until you see the rectangular flat circuit board attached to the glass assembly- display circuit board which is round. The round part is where the glass display is and where you are going to adhere the film to.
9. Turn the gauge on its axis or rotate it, so you can remove the two screws that hold the rectangular circuit board to the round glass display assembly circuit board. Remove the two small screws that are behind the display assembly that attaches both circuit boards together.
Note: Be very careful when inserting the screws to attach the two parts together, the plastic where the screws are inserted is delicate and if you insert the screw and force it in, you will break the plastic insert. Make sure that you insert and turn the screws with your hand first and only tighten slightly.
