How do I clean up and protect electrical connectors from corrosion? I bought an old 2004 Arctic Cat 400 ATV changed the starter, battery wasn’t charging so I ohmed the stator and checked the ac voltage output from the stator, tested good, less than.5 ohm and 70AC volt output. Ordered a new voltage regulator and when I went to change it, I noticed melted connectors. From what I read this can be caused by bad connections, and I’ve already seen some connectors that were pretty corroded. I’ve seen electronic cleaner? I have just used sand paper folded over buy wanted to see what the proper way is?
