azirkhan New Member Jul 19, 2012 #1 I bought the Steering Bellows Kit, proceeded to change it out, but the nut at the end of the cable is in the way! any suggestions on how to remove this not? Thanks. Attachments Bellows.JPG 53.2 KB · Views: 38
azirkhan New Member Jul 19, 2012 #2 Never mind, its done. I soaked the thread in PB Blaster, held the steel bolt with a vise grip and unscrewed the nut with a spanner. No issues. Last edited by a moderator: Jul 20, 2012
C crusty seadoo New Member May 6, 2013 #3 Where did you find the bellows. Mine are torn and need to be replaced. Thanks
Dr Honda Well-Known Member May 6, 2013 #4 It's a standard "Moris" or Telefex" type cable. Hit a regular boat shop, and they should have some generic replacements. FYI... DO NOT run the boat without the boot. It keeps the water out of the cable. An $8 boot can save the $150 cable.
B buckeye_paul New Member May 6, 2013 #6 Dr Honda said: It's a standard "Moris" or Telefex" type cable. Hit a regular boat shop, and they should have some generic replacements. FYI... DO NOT run the boat without the boot. It keeps the water out of the cable. An $8 boot can save the $150 cable. Click to expand... I looked for generic boots last year with no luck in that size. I ended up buying them online at Seadoo Parts Warehouse. EDIT..... I got those parts from Boats.net Last edited by a moderator: May 7, 2013
C crusty seadoo New Member May 7, 2013 #7 Found the boots from a place called sunset marine. They have different parts diagrams that seem to be more detailed when looking for obscure parts.
