Hi all,
I've got a unique situation developing here that's been a problem for at least the last 2 impellers (hopefully not the 3rd one too). I was told that I needed a new impeller as the wear ring was replaced so I purchased a reman from SBT and when it came I installed it and instantly noticed that it spun free on the wear ring. I put it all back together and tried it and just as I thought I was cavitating like crazy. I took the pump to a local shop where I was told that there should be no light coming from around the edges of the blade against the ring (which in this case there was). I called SBT and told them what happened and they shipped me another reman impeller. I just received it and put it back in the pump now without tightening it to spec but hand snugging it on there I noticed this time this was the first one to actually touch and put marks in the ring however just at the very edge of the blades. Does it have to be all the way around or it is just the very tip (like last part of the blade) that is supposed to touch the ring? One guy told me that if I can fit a couple of business cards in between the ring and impeller I am OK but the last thing I want to do is reassemble this thing and get it all the way back to the lake for the same result.
Any advice would be greatly appreciated.
Thanks!!!
Thanks!!!
