I have a new to me 2000 GS with the 720 motor. The previous owner claims it was running well then on day wouldn't start when leaving from the dock. I'm a first year seadoo'er but have a fair bit of experience with the older carbed rotax engines.
The engine has compression of about 125psi on both sides, has good spark, and the starter turns it over well. I can get it to sputter for a bit if I put gas into the carb, but feels like the timing if off. It sputters really rough and will only run when I hold the throttle wide open. It also seems to spit out from the carbs a bit which seems odd to me, but doesnt backfire. It had a some crud in the internal filter but is all cleaned out now and I plan and changing the grey tempo fuel lines. After cleaning, it still does the same thing.
I'm waiting on an RV degree tool to check the RV timing and plan on pulling the flywheel to check if the stator has moved or if the woodruff key has sheared. I've pulled the engine and noticed that the RV valve shaft has some rotational play in it. I would say it has about 5 degrees of play. I'm just wondering it that could be my issue? What amount of play is acceptable?
