...............The person I bought it from said he gave it a little more just to lube the motor a bit more,.............
That's not how it works. The internals are driven by a cam. So... once you come off peak... then it starts to lean out again. (not good at full RPM)
If you are happy with the idle speed... adjust them properly.
But... to your question......
It depends on how you drive. Those engine will go to 75:1 at idle. So... low speeds will burn less oil. Holding it wide open for a long time, with suck the oil down. Generally... a tank of oil will last 3 tanks of fuel.
Thanks I will check it out. If I remember the manual reading correctly, you adjust a cable to get them lined up.
We do a fair amount of cruising around at 5200rpm with an occasional wot spike in smooth water for 10-15 seconds. Just now getting the spin out down and perfecting it.![]()
This is looking about right for my oil usage. My oil is costing me about $48 a gallon out the door at the Seadoo dealer down the street, 2.3 gallon tank. So due to the oil, I'm adding about $30+ to the cost of a tank of gas. Gulp..
Yeah, I stopped going out and just joy riding around in my boat about 20yrs ago, LOL, I started using my anchor every trip almost.
As noted earlier I rarely go over 5000-5300rpm, even to plane out. I'm new to the jet drive, had i/o's for 30yrs. I'm spending as much as my friend with 24ft- merc 454/ bravo. I just had no idea... Guess I'll be tossing the anchor a bit more.
I've been looking for that $32 gallon case deal, so far can't seem to find it cheaper than the $45ish gal, case or singles gallons.
