Still chasing down a gremlin on my 2002 X20 - with a 2001 M2 SJ240. At any time you could walk out and bump the key and it will fire right up and run great. Quick off and ons and there’s no issue. After you run it for a longer period and go to restart it just turns over. Let it sit for a few hours and it will start right back up. Engine is cool to touch after running, no codes and I changed the port side temperature sender last time out to no avail. Although, it did work fine most of the day and then stranded us.
I found an older thread where someone had similar problems and it was concluded that the injectors were leaking down and flooding the plugs, causing the no start. Fuel would evaporate after a couple hours and run again. With this information I just ran mine with a fuel pressure gauge hooked up (on the trailer). 33 psi while idling and then it loses a few psi right away when you shut it off and then about a pound a minute thereafter. When it got down to about 10 psi I pulled a plug and it did look a little bit wet. Put it back in and bumped the key and it fired right up with no hesitation. How long should it hold pressure to indicate no injector leak down? Could this still potentially be my issue anyway since it will start right back up after short run cycles? Thanks
