You should be able to narrow it down using the specs.
Process of elimination.
If it is a 3 seater it's GTS or GTX
GTX has multifunction gauge, GTS doesn't.
If all else fails, pop the seat and look under the air box. 1 carb - GTS, 2 - GTX
Now if you have a 2 seater, it gets a little trickier.
You have either
SP
SPI
SPX
XP
The SPX and XP have the VTS system. If you have it, you have one of those 2, if not you have an SP or SPI
The SPI has the Eletric fuel gauge with low oil warning light and a few other options that the SP doesn't have.
As for the SPX vs XP, the easiest thing to look at is the impeller housing and venturi nozzle. IF it's aluminum, then it's the SPX if not, the XP.
Hope this helps.
