WaterEnthusiast
Hi,
I recently purchased a 2008 Sea-Doo Wake 215. As I was following the instruction from this site on how to winterize it, I questioned whether it was worth it disassemble the impeller (see video previously linked, from 7m07s) and put the grease back in place. Most people on the various forums told me not to bother, but I decided to be rigorous and open the impeller anyway. As soon as the cone came off (and I am concerned I may have damaged the cone itself while prying if off - picture to follow), a good amount of water also came out. The person in the video (and another one I used - here, in French, at 27m27s) states the importance of ensuring that no water has penetrated through, but they don't say what do I do if there is indeed some water in there..!
Looking at the 2 o-rings (Parts #22 on this assembly image) they don't seem cracked or damaged (although I've had to replace many rubber gaskets and finds on this Sea-Doo), but I have not taken them out to really inspect them.
My questions are as follow:
1- How do I determine what allowed water to penetrate?
2- The guy in the above maintenance video suggests to REPLACE the 3 impeller cover screw. This seem a bit zealous... Is this required? Why?
3- As you can see in the picture below, while prying off the impeller cover, I have worn it a bit, but I don't think it is critical. Do you think I need to replace it?
4- Do I really need to replace the 2 o-rings (part #22 in above link) each year...?
See pictures:
1- Old grease and water inside the impeller
2- Water inside the cone
3- After cleanup
4- Damaged cone while prying off
Thanks for any advice or input.
PS: I later stumbled on this great post that gives some details on how to remove the impeller cover. I wish I had seen it before I did my own disassembly: this great post
See pictures:
3- After cleanup
