Greetings. After having some work done on my carbs one of my engines idles quite high. Not sure how high as the tachometer for this engine is broken. How do I slow it down?
TY
single or dual engines?
you should get an inductive tach and not try and guess... in water should be 1500, and out of water, as in when flushing would be 3K+-.
you also need to verify if the throttle cable or steering assist isn`t hanging up the throttle.
Now, in quite a few cases the MAG carb seems to stick at the throttle shaft. a simple test would be to start the boat in the water, as it is idling high as you describe, reach you hand under the airbox and see if the throttle linkage can be moved to slow down the idle. If it can, then you either have the throttle shaft sticking or the cable...
It is a crazy procedure to check and make sure everything from oil injection pump cable travel, throttle cable tension free at WOT, and the steering assist all at the same time... including a reference/index mark on the linkage attaching the 2 carbs together to check for carb sync. assuming you have the 787 engines.
this worked for me by the book for base idle adjustments, and it was very very close to 1500 in water idle.
turn the
idle speed screw (T) out until the throttle plates are closed or there is a gap between the end of screw and carb tang/lever. Now turn in the idle speed screw (T) until it just comes in contact and touches the carb tang/lever. Turn the screw in 2 full turns!... this should get you in the ball park...
There are a few aftermarket tachs that run off the spark plug wire... Tiny Tach commercial, made by Designs technology, and TTO, hardline and a few others you can find on Amazon... here is the link for the TT commercial unit...
http://www.tinytach.com/
hope this helps somewhat...
