Trying to track issue in port engine. Engine is shuddering and won’t go above 2.5 rpm - have done cylinder test : all 120
Have done coolant pressure test and all holding.
Changed spark plugs.
how do I check the following;
Impeller is working
Jet pump is good
Supercharger is fine (just done rebuild)
what else do I check before taking to the shop?
If the drive shaft is having issues would it stop the impeller from providing thrust?
Impeller is working
Jet pump is good
