Hey All,
I have been having problems with this Seadoo. I recently bought it in not running condition. Thought I could get it going but it is not working out... heres whats going on...
I have spent the last 3 days researching, reading, and looking through old threads. I have the owners manual and the repair manual.
I have a new battery. I have 155 compression on both cylinders. I have new sparkplugs w gap set at .020in. The best matching plugs I could find at auto parts store were Autolite 404. (That is what we found when we crossreferenced champion RN4C.) I also am sure I have the tether cord properly installed while trying to start.
I have a strong blue spark on both plugs.
I already have all black fuel lines. I, using premix (32:1 or 40:1) and am getting fuel at the carb. This seadoo has the single BN38. My external fuel filter is clean.
When I crank the engine it just turns and does not even act like it wants to start up at all. When I pull plugs after trying to start, they are pretty wet with the fuel/oil mix.
I have tried spraying wd-40 into spark plug hole for a few sec, cleaning/reinstalling plugs, and trying to start. No start, No backfire.
I have also sprayed carb cleaner into carb, held throttle open and tried to start. Did a little backfire and made noises almost like its trying to crank up but does not start.
SO... I figure im getting too much fuel. Maybe needle valve sticking. I also wanted to check on the filter in the carb. I followed all the carb links everyone on here has and could not find one specific to my carb. I took off the carb and cant find the internal fuel filter. The needle valve assembly seems to be correctly adjusted. And the inside of the carb looks pretty clean.
When I went to inspect the rotary valve I found somthing that looks bad. There is a large burr (small carved out piece of the block) behind where the rotary valve spins. This has caused a raised area across the entire surface of the rotary valve. I think somthing came in through the fuel line and got jammed between the valve and block. The block not only has that huge burr but it also has a line dug out going all the way around in a circle and ending at the burr. The burr comes out about .02in to .03in...
Would this cause the no start problems I am having? Can I repair the groves on the block?? If so, How?
Please Help!!! will try to get pics of it on here soon!
