If it hasn't changed dramatically from my 2012 Speedster, then you connect the hose in the back next to the starboard side of the pump. You should be able to screw the hose into a threaded connector. Use a flashlight so you can see where it goes. You might find it easier to move the shifter into forward so that you can move the bucket out of the way. Also, in the future, getting a quick release kit for the hose makes this task much easier.
