Toolanddiemaker
Just wanted to share some pics of my homemade leak tester. After doing some researching I decided to takle this proj and machine out some block off plates I also bought a sheet of .125 rubber gasket material from Ebay. I ended up using the jet pump leak tester I put together with some t fittings linked to the intake plates that I drilled and taped for 1/4 in npt barbes fairly decent setup for a first timer ,I think! anyway pumped up the shraider valve with a hand pump and it held around 8 to 10 psi for around an hour then dropped and held around 6 I sprayed soapy solution on everything and I couldn't find any leaks. I will check it in a few hours to see were it's at. I also tested the rv cav and it held 10 psi indefinetly.The pic shows 0 psi on the gauge but that was before I started the test.Keeping my fingers crossed this was my first rebuild so im expecting a learning curve but I hope I don't need to rip it all apart again! Sorry for the long post thanks for reading!
Sent from my SGH-T769 using Tapatalk 2
