high speed wobble
jimmy 3862
:redface:1994 XP that at about 4500 RPM starts wobbling back and forth,
gets worse with increased speed....seems to run fine otherwise...
I would check the impeller shaft and bearings. Is something in the impeller area by chance... a stick or something?
Karl
checked out the impeller and under grating,,nothing there...
looked at my GTI and the angle of water for drive was very
different..my VTS does not work so I got a manual and found that
my output module is bad and motor is open, so I manually
adjusted the angle to match the GTI as close as possible, and
took it out and ran it,,no more wobble,,,must buy parts for VTS...:cheers:
What is vts?
I am having the same problem. I just replaced a piston & Rings, I also rebuilt the carb. I noticed that a washer around a bolt holding the motor to a mount was vibrating when I was testing the engine. I tightened the bolt (I think about 1-2 turns). Now it runs great, but above 24 mph it starts wobbling. Should I untignten the bolt? What is the VTS referred to above?
