Hi everybodyOil for 717
It is hard to say......
So API-TC and TCW-3 are two completely different testing and additive package requirements. If you go back through all the technical documents and testing of the two certifications they are so different that they can't really be the same oil. So the rule of thumb was never run a dual rated oil as there is really no way to meet both certifications. The minimum API-TC rating might pass but isn't what you want in a Seadoo. Seadoo requires API-TC low ash oil. The low ash is important.
Here is a response form a Rotax Engine Engineer, it is about Rotax aircraft engines but applies to the Seadoo (Rotax) engines also.
"Hi Larry, you’ve asked a great oil question that really stirs up a lot of two stroke pilots. I have spent a lot of time researching to stroke oils. If I ask about engine oils when presenting a seminar, it seems like I’d get a different favourite oil from each attendee. Ok, here goes my opinion on the great oil debate.
Our Rotax aircraft engines operated at high load, high rpm and high piston temperature for prolonged periods. For our application the correct oil specified is API -TC (low ash) rated oil, period! This applies to to the aircooled (503) as well liquid cooled (582) aircraft engines equally.
A boat or watercraft engine is cooled by cool lake water and this engine application experiences much lower piston temperatures. These craft use TC-W3 rated oil.
A boats engines exhaust exits under the surface of the water. This reduces the exhaust sound level, however the products of combustion enter the water directly. TC-W3, (ashless boat oil) has an additive (detergent) package made up of organic substances to reduce water pollution. TC-W3 organic additive package will not withstand the much higher piston area temperatures our Rotax aircraft engine experience.
Our API-TC (low ash) oil for use in our aircraft Rotax aircraft engines has a additive (detergent) package made up of metallic substances (heavy metals) . This additive package is what allows piston area protection at much higher temperatures.
True API-TC oil users make up up a small percentage of the market, so oil companies have reformulated TC-W boat oil to also pass the minimum API-TC test standards. This fits all engines oil blend is like a “one size fits all” piece of clothing. I believe this dual purpose oil blend must contain the low temperature operation organic additive package or it couldn’t be used in a watercraft.
I would recommend you use only a specified standalone API-TC oil to protect your Rotax aircraft engine. Rotax has documents referring to correct operating fluids, including two stroke oil.
Regards John Baker iRMT 3852"
