Hey guys!
So I’ve been lurking on this fine forum for a while doing my best to try to learn what I need for my current boat, it was really helpful when I noticed my RAVE value’s were leaking and I had no idea what to do!
However, now things are at a WHOLE different level!
First some background, I have a 1996 Seadoo Challenger with the single Rotax.
The engine has not run right since I got it, first the raves were burnt(literally both were stripped and one had the nut ripped right off the piston cover) That went on for a while before I figured out exactly what they were.
Along with that, she would cavitation like HELL, it would be nearly impossible to get on plane and when It was on plane I could hardly break 35mph on glass water, eventually I figured out about the wear ring ect and replaced the (dinged) impeller, wear ring, all the seals and the carbon seal and all the o-rings, checked the shaft/play and it was good.
So now.. I got everything back together and it wouldn’t start… odd, so I ran a compression test… 145 .. 20… Noooooooooooooooooo!!!
Last time I had it out for some reason she had started to act weird, dropping revs slowly, it was a REAL effort even at WOT to get it to 6k and it just felt like it was dying, it never died but I limped in it, that’s when I figured out about the rave valves and wrote that off to that.. However now I think I was wrong.
So, I included some pics, yup, that’s a –hole- in the piston! Also the cyl wall is scared all up. You can feel it running your figure on it, the rave valve (the new one) doesn’t seem to be dinged at all in any area so perhaps it was the old one?
So my question is… um next move?
I had a thought of pulling both jugs out, and the piston heads and getting a head rebuild kit that you see online, 2x new jugs/piston heads and slapping it all together… will that work? Is there anything really important I need to know about pulling those off? Unless I judged it wrong I should be able to do that with it still in the boat…
Any options or general NO YOU CANT DO THAT? Lol
I’m trying to avoiding taking it to the stealership because they already quoted me close to 2grand to repair it…
I included a bunch of pics I took.
Cheers!!! I'm off to have a few beers and convince myself its allll ok
