'02 Utopia w/the 240efi Merc.
Leaving the dock last weekend I noticed that my speedo was jumping all over the place...hmmmm. As I got near the channel, the overheat alarm sounds so I dropped the hook and got under the boat...the intake is clear and the speedo wheel also spins freely. Hmmm. Try a few more times and the same thing. Finally, I back her down hard...and then everything is fine for the rest of the day: Speedo works fine and no alarm. Made sure I flushed her out really well when I got home thinking maybe some junk was in the cooling system. Also changed out the water/fuel separator, although that would have been a beeping alarm, not continuous.
So, This weekend, same thing....speedo crazy...then the alarm as I'm idling away from the ramp. This time it was intermittent.
I thought maybe the overheat sensor is bad....but it seems related to the wierd speedo behavior. I can't imagine how those two circuits are related. The connections for both the speedo wire in the bilge and the overheat sensor on the engine are clean and tight. I ordered a service manual which I should have this week, but I'm hoping to get a jump on this. It has to be electrical as the problem first starts with a cold engine idling. Wierd. :ack:
Mike
Mike
