vigalass
I'm back at the lake now. Aiming to fix my 250 Optimax 2002 that keeps dying after about 10mins of driving through no wake; and then won't restart for 30mins. Then will hard start and die again in another 10mins.
Here is my plan. I welcome input on the order and blind spots.
0) hook up fuel and air pressure gauges (already checked them at 95 and 85 fuel and air)
1) check the crank trigger wires for insulation delamination
2) pull current plugs and replace all six
3) replace port temp sensor
4) idle test and pull out each injector one at a time to see if the idle changes to see if all 6 are firing.
If all 6 are idling then Test Drive - bring can of fuel. If it dies pull feed fuel directly from clean fuel can
4) if won't start install 6 inline spark testers and monitor spark while driving
5) install new Crank Position Sensor
test drive - if still dies. return to dock and
5) pull fly wheel and investigate crank trigger equivilent on this DFI
6) replace each fuel pump starting with cheapest first and test driving.
I shoudl weave in seeing if i have a throttle gaurdian and kill it, and look for the black/yellow wire and snip it.
And pull tether switch out and bypass.
If this doesn't work I have a boat for sale!!
Victor
Victor
