The siphon hoses should come from the pump go up just below the seat before they go down to the siphons. If they are running straight out of the pump to the siphons they will leak. Hoses need to be higher than the waterline.
Just wanted to update. I found the issue. So if you’re taking in water from your bailers is most likely because the little o ring or nozzles are missing. Mine is the one missing one.
