Hi,
after my Seadoo Sportster shut off while riding, I found out my partner used about 2.5 quarts of Yamalube instead of the usual XPS. I have always used XPS. Engine ran perfectly before this incident, now it doesn't want to stay started and when it does start it dies out. I've cleaned the carbs and changed all the oil from the oil reservoir all the way through the lines, removed oil filter and replaced and got what I thought was most of it out. I need some direction before I end up forking over major dollars to a repair shop. Any help would be appreciated..Thanks
