Hello,
I would like to change out the air temp sensor, the head temp sensor, and the coolant temp sensor on my 2001 M2 V6 Jet Drive Challenger 1800, as I have read this is a relatively quick/easy/cheap first fix if i am not getting full power (35 mph max at the moment). Can anyone provide on advice, pictures/instructions etc. on doing this job please as i am a noobie, and not the most mechanically minded.
I would also be grateful for a parts guru to qualify my part #'s below are for my model/year boat (my engine serial number is 0E386098). I am ordering these from eBay, but if there is somewhere better to order parts for my boat from, i am all ears
Mercury Marine/Mercruiser New OEM TEMPERATURE TEMP SENSOR 13221T01
Mercury Marine/Mercruiser New OEM TEMPERATURE SENSOR-TEMP SENDER 13536A14
Mercury New OEM Engine Block Temperature Temp Sender/Sensor Unit 974651; 97465 1
Thank you in advance!
