Dg1148
2012 rxp x 260. Not too much info about this code. I'm hoping it's just the sensor. Have one ordered and its on the way. Was wondering if I should be looking at other possible faults. Completed a riva intake manifold upgrade and after I got everything back together I had a map sensor code and the p1505 code, referencing the tops switch. I replaced the map sensor and that code cleared. Still have the 1505 code. Hoping I was just sloppy with the install and accidentally got the sensor wet and shorted it somhow. Cleaned all the other plugs with electrical cleaner just to make sure. Ski has noticeable power loss and will not much spin more than 7500ish rpms. Mods : riva 8350 tune, 12.5/21 solas prop, 4" intake, fizzle intercooler, riva intake manifold mod. Any other possible insight would be great. Thanks guys.
