Hello,
I was hoping one of the members here may be able to help me with my new boat. I have read many of the prior posts, but could not find an answer to my low rpm/low top speed problem. I have always owned Seadoo PWCs, 95' SP, 97' XP, 2001 XP. I have always tried to do a lot of the maintenance myself, with the exception of major engine work.
I recently purchased a 2005 Sportster 150 with the 4-Tec 150hp non-supercharged model. I took it to my local dealer for a thorough inspection and service since I did not know the history of the boat. Based on the service advisor, it currently has 150 hours, good wear ring, and no nicks/damage to the impeller, no motor issues, no fault codes, etc. I just had a full service with oil change, all new spark plugs, oil filter, check all cables, etc., and was told everything was in excellent condition.
I just took the boat out for the first tome this weekend but was unhappy with the performance. Top speed was only 39 mph (per GPS) at a maximum of 6,100 rpm's. It also took approximately 6-7 seconds to get on plane. This was with 2 people 175lb each, no gear, and a full tank of fresh gas on water that was flat like glass. According to the shop manual the max rpm's should be 7,650 and I understand from reading many of the forum posts from sportster and speedster owners of non-supercharged boats that my top speed should be approximately 50 mph at those rpm's. At this point the dealer says there are no fault codes and does not know what the problem could be. Any ideas? Any help would be greatly appreciated. I was set on buying a non-supercharged unit because I was fine with a top speed of 50mph, but I am not happy at all with 39mph. I hope I don't have to go to a SC model. I really like everything about the boat with the exception of the slow top speed.
