BoLongo
Seadoo specs large high speed jets in the 787; the setting for the high-speed adjustment screw is set to 0. You can only make it richer you can’t make it leaner
I want to be able to have the same stock fuel mixture when I turn the high-speed screw; 1½ turns out. I understand that I will have to lower the size of the high-speed jet, so the high-speed screw becomes active. Turning it in will make it leaner and turning it out will make it richer.
I will have EGT gauges so I can monitor internal temperatures to prevent piston damage. I have been all over Group-K and other racing sites, but I am not finding the information I'm looking for. I want to make my two 787s runs as efficiently as possible. I know the engineers at Seadoo are coming from the point of view of making the engine run as rich as possible to prevent engine damage. I want to get a little closer to the line between running too lean and running too rich. Why? Because I am OCD like that.
Before I make any changes to the jetting, I will establish a baseline exhaust temperature using the stock setting other than the high volume fuel pump which I have already converted. From there I will slowly lean out the carbs noting each change in exhaust temperature. 80% of the time I will be in the 5000 to 7000 RPM range; so I’m focused on the high speed jetting.
I do not want to buy ten different sets of jets, so I am trying to estimate the best set of high-speed jets to start with. Currently, my high-speed stock jets are 140.
Any input would be appreciated.
