Long time listener, first time caller- mechanically minded but Sea-Doo experience is limited to this 97 gtx I picked up for what I thought was a good deal in 2017. It ran and I had a great first day- but an oil leak from the return line ruined my life. Couldn’t get it to stop leaking, broke the seal on the exhaust and then had that leak too- wife was fed up and I left for a year courtesy of Uncle Sam.
Fast forward to 2019, we’re moving, wife says the only way I can keep the gtx is if it’s running by Monday. Since I’ve been working on it and it’s sat for 2 years, I’ve replaced all oil lines, oil filter, fuel baffle, fuel lines, fuel filter, fuel selector, exhaust, and rebuilt the carbs with Mikuni kits. She ran yesterday on the hose for a few minutes, adjusted the idle up to 3200 RPMs, things were looking good, until today.
Got her off the trailer into the water, she cranks and idles at 1450 rpms. Start taking a low speed cruise and she sounds a little boggy but it’s relatively ok for low speed. Hesitated at 4K rpm and then jumps to like 6+ and takes off- felt great! Did that again and pulled the lanyard and plugs. PTO plug (1x low speed and 1/4 turn high speed) looks like cocoa and is dry- thought maybe a little rich but ok. Mag (1 turn low speed, 0 turn high speed) looks white! Not chalky it’s just not colored- looks new. Get back to the dock and turn the mag high speed screw to 1/4. Try to get back out, she idles fine and then dies when you try to accelerate. Died at idle on the main fuel line (I may have turned it off?) pitted back to the dock on reserve and put her on the trailer.
Get home and flush her, idles at almost 4K rpm. try turning the low speed screws up to 1.5 turns- carbs were still mounted, didn’t feel like the two carbs were exactly the same, fired her up and idle was now at 1500-2k; figured I might have to reset idle but it was a little rough so I took off the carbs and set them back to 1 turn. Fired her up and BANG, loud noise. Pulled the lanyard. Fired her up again and she sounds fairly smooth but idle is now down to 1500, even with default low speed settings. I’m concerned that I just toasted a cylinder or I’ve got bigger problems.
Of note, I didn’t have a pop off gauge going past 30 so not sure the exact pressure there- tested all of the valves in the carbs. Autozone pressure tester 2 years ago said 120-119 compression- maybe she’s toast anyway but if anyone has any ideas on what I’m doing wrong please let me know! Also of note, ran the regular fuel line on the trailer at home and no issue- don’t think there’s a blockage there.
I appreciate any help or advice!
