bradvincent@bellsouth.net
I have a 1997 Speedster. I replaced both wear sleeves. One of the sleeves has a significant gap between the sleeve and impeller. I swapped impellers to see if the impeller was damaged or worn and the same sleeve has the same gap with both impellers. The other sleeve has a paper thin gap with both impellers. Is it possible the sleeve is defective or is there something else that could be wrong? both sleeves are brand new.
