Help seadoo hardly running
mittsd
The problem that I am having with my sea doo is that it is really bogged down and will stall. If i travel anything over 3000 rpm it will run for a bit at that rpm then just die. The higher rpm the faster it dies. This started happening after I took the baffle out to try to get the gas gauge to start working again. I also cleaned the fuel filter out some. I then put it in water and ran at about 40 mph for a little bit, then to 35, until it just started dyeing, unless it was just idling or just above idling. So I thought that the crabs need to be cleaned so I took them apart and cleaned them and put them back together and still is do that. This started on the second time I took it out, the first time it was just bogged down at high speeds, like the crabs need to be cleaned, but I needed to test to see if gas gauge would work so I took it out again and that’s when this started.
It is a 2000 rx with 152 hours on it.
Any help would be great.
Also where is the best place to have seadoo work on in Central Florida, I live about an hour south of Orlando.
Thanks
Yes I bleave i did, is there a digram that i could find to double check? Whould the jet run if they were on backwords? When i cleaned the carbs i did not check the fuel pump, could that be it?
