Hi all, I'm new to the forum and this is my first post. I just bought a 1997 XP and a 2000 GS and took them both to the lake yesterday for the first time. XP ran fine but I'm having an issue with the GS. I had to go through the carb when I got it because it had a bad bog. I found the accelerator pump was plugged up on the intake side so it was not working at all. I got that fixed and the ski sounded great on the trailer. On the water, it starts and idles fine and pulls hard out of the hole but when I'm going WOT in choppy water and the pump comes out of the water it has a major bog....bad enough to almost throw me over the bars. It's like the DESS key got pulled off or I hit the stop switch. Once it slows down a bit it catches it's breath I can hit it again and it pulls strong again. Seems to do it anytime I would expect to hit the rev limiter. I can hold it WOT while turning and keeping the ski loaded up and it never misses a beat so I don't think it is fuel delivery and the cut off is instantaneous so I'm thinking it has to be electrical. The ski does have an aftermarket MPEM, any known issues with aftermarket MPEMs? Any other suggestions?
