Edmund1111
I just got a 2002 GTI LE I'm trying to pull out the drive shaft but the stainless steel top hat looking thing by the carbon seal is stuck on, I can turn it with a pipe wrench and WD-40, but it won't slide back. The top end of my engine is disassembled, lower half is still in the hull. If I take out my engine can this drive shaft just be removed by sliding it into the hull instead of pulling it out through the jet pump?
