97 gtx
I have a 96 gtx 787 the thing runs great on the hose I’ve done all kinds of work to it and can’t get it just right
Carb rebuild and clean, new gas lines and bet cock and filters, new rectifier and stator, new wear ring and rtv the jet pump housing deleted the oil pump for pre mix new plugs and wires.
I had two RAVE VALVES that were broken when I took em apart I sourced some used ones off a parts ski but still seems to want to flood the engine out she’ll jump out to 7500+\- and run great then it’s like it falls on its face and stalls and sputters down to 3000 give or take and stalls out usually starts right back up but normally the first couple minutes it’s fine. My redneck jet ski mechanic told me to get a straight pipe to do away with the water box and rave valve on that water box all together that it would be loud as hell but might fix the issue but if I rolled it I’ve got to be carful to roll it the right way or he said I could flood the engine out since theirs no rave valve there to stop the water. What’s y’all’s thoughts? Just find some NEW raves and replace them all? Get a tdr water box? Or straight pipe it
