harley dad
Hello all and thank you for any help you may have.
Ok so hears what I have. She will run on hose no problems at ANY RPMs for any length of time.
But when I put her in the water she will idol fine and even come up to around 3000rpms
but after that she will seem like she is maybe starving for fuel or something and just shut down like the key was turned off.
She will start right back up and have no problems at all idling or coming up to 300rpms.
She has new fuel pumps and filters new oil pump , reed boxes , plugs and coils.
She has over 110psi compression over all 6cyl and 35psi fuel pressure.
Water flows out the pisser.
Not sure if there is a bad sensor or switch that my be telling her to shut down.
I had a EFI boat (not a see-doo) that had a bad oil pressure switch that made the boat never go over 3500rpms and it drove me crazy till I found it.
Any thoughts or ideas would be great!
Thank you!!!
Thank you!!!
