I have a 2006 sea doo rxt 4tec when I give it full throttle I get power but it sounds rough and the temp light comes on. I dont know if I need a new impeller or what?
Thanks in advance~ Harold
Welcome to the seadoo forum Harold. You have the 4-tec engine with inter looping cooling. Is the anti-freeze up to the correct level? The Temp light shouldn't come on unless it is over heating. The impeller wouldn't cause the Temp light to come on. Is it throwing any trouble codes? Push the set button 5 times and check to see if its throwing a code, and re-post here.
