Hrobertson1
Hi all,
I bought my 95 speedster quite a few months back and have been going thru it. Every trip to the lake has resulted in getting towed back in or near sinking. At first I was having a over revving issue, come to find out the new impeller that was put on for me was for a 586? motor and not the 720 I have. Got that fixed and it was running way better. I had a seadoo mechanic tune and adjust the carbs wich made a difference. The last trip out I thought everything was fine, then the steering got a little tight, then real loose. After spending a few minutes turning in circles, and a tow back in, I found that only 1 jet was turning with the steering wheel. I also found that the cables (steering and directional) were leaking water, not a ton but enough to be concerned. Is there directions posted anywhere on how to replace the cables, I figure with the issues I might as well replace them all. I have a fair amount of auto mechanic knowledge, but I know this is a whole other story.
My final question is with getting on plane. My brother had a speedster when we were younger and it would almost jump out of the water and was quick. This one seems to take about 20 seconds unless I have a second person and direct them to the front of the boat then its a little quicker (I weigh 175). It still seems way longer than it should. And my top end speed is about 30-35 mph per gps. I have tried different methods, but all result in the back end squatting down, the engines revving and it slowly climbing to plane. If I take a turn too tight I again have to make the climb up to plane again.
Any help or direction you could lend would be greatly appreciated.
Thank you,
Henry
Thank you,
Henry
