I took out the drain screw at the bottom of the vst and with the key on i don't hear or feel anything from the vst, I just hear the lift pump clicking the flow of gas starts slow gets more steady then after the lift pump stops the gas flow stops.
I looked for the Black and yellow wire for the kill switch couldn't find it.
I attached a picture, is this the guard box you spoke of?
Thank you very much
I checked the voltage to the pump it was 11.8v. I took off the vst and pulled out the pump. I put 12v to it and it ran quite well. Should I still get a new pump? It was definitely not working in the boat
I was doing some more diagnostics, there is a relay next to the fuse for the lift pump what does it control?
I thought I had disconnected the throttle Guardian but I guess I didn't cut the right wire. I cut them all and reconnected black and yellow and voila running like a champ.
Tim75 I can't thank you enough. Thanks for hanging in there with me everybody.
Geoff
