Impeller and wear ring question:
Last week I had a rock stuck between the shaft and the intake grate I have the original grate that opens. I was able to take it out from the intake grate and I thought I got lucky since it didn’t go through to the impeller. My boat is cavitating now and not going past 10mph.
What should I check do I need an impeller and wear ring? Should I change anything else?
I found an impeller on Amazon is this the right one? good brand or do you guys recommend something else.
SOLAS MC-CD-22/39 - Impeller/Concord Amazon.com: SOLAS MC-CD-22/39 - Impeller/Concord : Sports & Outdoors
Where do you recommend getting the wear ring? I found this.
Sea-Doo Wear Ring (155 MM) GTX/Speedster/Sportster/Utopia/GTI/Islandia/Challe...
Thank you
Thank you
