Lightningtruck
Hi all,
I know this is the PWC forum, but I'm working on my 2004 Sportster DI and know a lot of the powertrain carries over to PWC, and there seems to be more traffic here.
Anyway, I just replaced the stator, which of course requires taking off the tuned pipe, throttle body, and pulling the front engine mount. Then lift up the engine to expose the bottom row of bolts for the stator housing/cover. Did that no problem, but I screwed up in the process.
I put a 2x4 under the starter to gently lift the engine up, but little did I know there was something I think plastic under there. There is a hose that connects from a small chamber on the stator housing (from a small cooling chamber), and it runs under the starter and connects to this plastic blob. I unknowingly broke the fitting off of the front of the plastic blob with the 2x4. The other end of the plastic blob runs a water hose back to the exhaust.
Question is, what is this plastic blob, and what does it do? It's not labeled in the parts fiche, and I can't find anything on it in the shop manual. From what I can see from the picture, maybe it's a heat exchanger of some kind, and that sucker is smack dab under the engine. Guess what that means if I need to replace it. That means I'm cutting a big hole under the engine and going to town. No, not really. But I am not pulling this engine!!!
Can I bypass this thing?
Of course I see this as I am putting the final touches buttoning things up.
I'm so ready to run my 4TEC.
Thanks for any insight.
Kevin
Kevin
