I guess my question was incorrect. The feed lines to carberator are intact. The line leading from the pump on the TOP of the tank off the pump is the one I am referring to which is about 8 inches long and is not connected to anything right now. Where does this connect? The other line from this pump leads to the base of the motor is also intact. thank you
