Today, I tried to do an oil change on a mostly even surface. No oil comes out of the oil extractor however, the dipstick indicates there is oil but close to the minimum mark. Just for kicks, I added a quart of oil and tried to extract through the dipstick hole and sure enough I was able to get some oil out. I dropped the front of the boat all the way to the ground and tried to extract more oil from the front of the engine through the engine oil cap. In total I was able to extract only about 1.5 quarts of oil (this includes the quart I poured into it). I tried adding 2 quarts of fresh oil and it overflowed out before settling down. Clearly, the dipstick shows I have excess oil.
What am I missing? I was under the impression, this engine takes 2.7 quarts of oil. I plan to redo the oil change since I cant drive it around with excess oil but I am not sure what different outcome I can expect to see.
