William_j_vega
Hello forum,
I have a 2019 RXP-X 300 that been sitting for almost a year. It was winterized prior to this. I'm replacing the turbo as it's time for a rebuild, plus I'm upgrading to a bigger impeller.
Here comes some issues I'm experiencing:
Stuck supercharger - I have pulled the charger out, but it's hitting the shaft while trying to remove it from the engine. It's the shaft bearing holder i believe. Picture attached.
Stuck pump - im also replacing the impeller with a Solas 13/18 and in the process of removing the pump, it stucked on the shaft. I have watched millions of videos and i don't understand why is not coming out. I sprayed penetrant and rust remover, slight tap on yhe impeller and even pull very hard on the back and it's not budging. Any ideas?
