help my 96 xp bogs at wide open throttle
xp537
the ski sounds great out of the water when I put it in the water it runs good but at like maybe 3500 rpm you can hear it miss a little just a little pop pop pop sound then I hold it full throttle and it takes off great then it will bog completly down and I have to let off the throttle and feather the throttle to get it to go again as long as I feather the throttle it doesnt die .the compression is 175 psi in both cyliders . I just changed the fuel valve and changed all the grey fuel lines but I havent got to test it again I also rode it with the seat off and the exhaust gasket is NOT leaking into the carbs and I just rebuilt the carbs so what else can it be a bad coil ,or maybe a clogged fuel vent, I just dont really know what else it can be
thanks LES
175psi...WOW, was it recently rebuilt?, if so, maybe RV not timed right, but with that compression, what octane you using.
