I recently purchased a 2003 Sea Doo GTX 4-tec Supercharged with 107 hours. I knew when I bought it that it needed an impeller and wear ring and a supercharger rebuild. I didn't know that it needed a whole new pump too. So now I have a new pump, Solas impeller, and rebuilt supercharger. After spending all that money, a hose clamp broken on my stainless exhaust manifold while riding and allowed about 4 inches of salt water to fill the hull, thereby tripping the exhaust hi-temp warning light/beep. The exhaust wasn't getting cooled properly because water was not circulating through the whole system. I pulled the ski out of the water and opened the rear drains and that's when I noticed an oil slick coming out. Back home, I fixed the hose clamp and ran the ski with a garden hose while I used my inspection camera to watch the PTO seal. It was pouring out milky oil (water in the oil) while the engine was running. Is it possible that my PTO seal is so bad that the 4 inches of standing water got in through the seal and contaminated the oil? I pulled the dipstick and there is milky oil at the bottom of the stick below the bottom notch too. Do I have a bad manifold that is allowing water contamination? The engine runs great and the compression is at factory spec on all cylinders. Any ideas what the oil contamination problem is? I ordered a new PTO seal to install, but I don't want to install it and possibly ruin the new seal if the water is getting in the oil elsewhere. I'm going to pull the manifold and check for any holes, but if that is OK, what else could be the source? I am not a PWC mechanic, I just have a good mechanical background and I've read a lot on-line how to replace the PTO seal. I'm getting in over my head and I need help.
