JoshDragon
I found this boat while looking for a pair of jet skis. Once I seen it in person and heard it run We decided to take it home. I got it with a wake board, tube and 5 life jackets.
I did compression test and ran 143-147 on all cylinders.
-1st time out ran her for 25-30 minutes decided to dive and swim off the boat got ready to go in and this happened left engine wouldn't idle or start with out giving it 1/4 Throttle. Right engine wouldn't run at all. Made pulling it in to the launch extremely fun! (This is my first watercraft)
-What I discovered/diagnosed trouble shooting when I got home, b8es plugs fouled with gaps between .038-.042, old watery gas, plug wire caps were stretched to were you couldn't feel it click on the plugs.
-What I did- drained all gas into my lawn tractor, new br8es since it calls for a resistor gapped at.022, 5 gallons of 91 octane ethanol free, snipped 1/4" off of each plug wire and installed new caps.
-2nd trip launched the boat started right up cold in the water cleared no wake WOT WOW! Played around taking turns driving it like a go cart inside the brake wall. Decided to take on the 2 foot waves even more fun! (My buddy and I are laughing and grinning while my wife is screaming and digging her nails in my arm) go back in the safety of the break wall,
She wants to drive it now! 10 minutes in runs out of gas so I switch to reserve left engine fires right up, right engine just cold cranks limp it back on 1 engine again.
- searched this site here and diagnosed clogged pet cock
- this boat already has fuel injection hose. I simplified two direct lines off the reserve line and capped the old regular. I added filters after the stock separators and petcocks about 10" before carb to switch off and idle out.
-3rd trip out found a new launch closer to home that is a lot easier on the clutch in my 2000 crv hd lol. The down fall is there is about a mile of slow river loaded with kayakers before hitting Lake Erie. It was also loaded with bald eagles saw 6 in our trip.
Back to point we finally hit the lake go wot then carve around for a bit stop to hook up the tube and give it ago. Mash the sticks and feels like a clutch Is slipping. Start messing with it and realize it's just the right engine. We start limping it back at about 4500 rpm is when it feels like slipping. I make my friend drive and pop the hatch under 4000 rpm I was getting a water spray under the pto shroud, at wot a noticeably more air bubbles in the right jet stream.
- what I diagnose carbon rings!
- I researched the job here and am confident I can do it. Opened the hatch to take a look and see if maybe I had a ripped boot but this is what I saw.
-this is what I was expecting
Thank you and sorry if it's a really long post I wanna get this sorted out fast snow will fly in 2 months
