1800chall_tim
today with the boat full of family, i ran aground on a unexpected sand bar. was going about 5 mph when depth alarm went off i slowed to a crawl but it was to late, felt it drag but didn't here anything scraping or dragging. just as soon as i hit i was freed and crept to deeper water. once in deeper water went to open up and got a horrible vibration/shutter from port side engine (instant ohhhh crap feeling) sooooo..... i took it back to landing slow and got it home. pulled pump (took all of 5 min.) wear ring is only damaged on the first 1/4 of it, near the first bit of impeller leading edge. but it seemed loose. in fact i pulled it out of housing by hand with impeller still in. is it possible the loose wear ring now spins with impeller? the impeller itself is only slightly damaged on leading edge, can i file it and save it? i have pics. of both is this enough damage to create bad vibration.
