Help finding a exhaust hose for my 98 speedster
rkkoeb
need help finding a exhaust hose for my 98 speedster. Part number 204340072
That connects the upper eagles wing to the lower. until you luck out, you should be able to remove the hose from the lower wing and connect it to the upper wing. All they are are silencers, that side will be a little louder when on plane. What's wrong with yours?
So it all started when I broke off the water valve on the exhaust can. This lead to melting the end of one of the Wing and had to be replaced. When I went to put everything back together last night I notice this hose is junk and you can just about stick your finger through it.
Well, if you take your time you can also eliminate the wings and go right from the water box to the outlet. I have done that one before on a speedster, I just don't remember what hose I used. But it was one of the ones that camber on the boat. You could also just use the ends and a piece of stainless tubing in the middle with some clamps.
