Help, do I have the right carb parts?
TubecatGS
1999 GTX Limited. Engine says Type 947. From all I read the 947 is also referred to as the 951 if it was fuel injected (correct?).
I was told by multiple folks that the carb rebuild kit is a Mikuni MK-BN46I. I compared pictures to multiple vendors listings of these kits (everyone seems out of stock on these and OSD was closed) and appears this is the kit that I would need. I was able to source parts from a supplier who really did some digging to round up Genuine Mikuni parts except the intake gaskets.... So far just the aftermarket gaskets arrived and that's it.
The gaskets are not correct. Pic 1 new and my original gaskets, Pic 2 new gasket on carb. Pic 3 947 intake.
When I look up just gaskets for the 947, it seems everywhere i look (see PIC 4 says "46") an ebay listing shows the same gasket i was sent and incorrect. I did find one listing for a gasket for a 951 that looks correct..... See PIC 5 (but says 50MM)
How can this be? I know which gasket I need (pic 5).... MY BIGGER QUESTION is, I was told that the carbs I have are the 46 MM... and the kit I need is the Mikuni MK-BN46I carb rebuild kits for the carbs on my engine (Type 947). The gasket looks to be a 50MM gasket...
What do I have and do you think i have the right carb kits coming in?
Thanks
The 947 and 951 is the exact same engine and size, just for some reason seadoo lists it both ways.
All 951/947 carbs are 46i.
Because of the aftermarket gasket issues I only buy OEM carb gaskets now.
293250135
Gasket
This part replaces 293250066.
MSRP: $3.58
Dealer Price: $3.58
