help changing wear ring on 99 gtx limited
xp537
I Have Read The Other Post On Changing The Wear Rings But It Seems Like Everything They Are Working On Is Newer Than Mine Just Wondering If Its Going To Be The Same Proces And Is The Freezer Method Or Ice Water Method Going To Work On My Pump And Will I Have To Pull The Prop Im Not Sure If It Has Ever Been Changed Before Thanks Les
