SeadooDavid
I need some advice before making a buying decision on a jet ski. I have a friend that has a 1996 Seadoo GTI that he wants to get rid of. He has only owned it for a few weeks and he bought it off of craigslist for the sole purpose of reselling. The owner before him said that they were the original owners and had serviced it regularly but they didn’t have the maintenance records. It does seem to be in overall really good condition though. He has only had it out on the water twice; once on a large lake and the second time on a decent size river. I was there and rode it both times.
So here’s my question/issue:
Both times it has run great for 2-3 hours and then it has acted up a little. After riding it for 2-3 hours it will drop in speed and then surge back up. Say you have the throttle held at what should be the 40mph position and you are cruising along at 40mph it will suddenly lose power for 1-2 seconds; just long enough to drop your speed down to 35mph or so and then it will speed right back up to 40mph where it should be. It will do this 2-3 times a minute for a couple minutes and then it will be fine for 5 minutes or so and then it’ll do it again a few more times. It doesn’t have to be at 40mph either. It will do it at all speeds and drop the mph approximately 5mph. I just used 40mph as my example because that’s roughly my cruising speed and where I spend most of my time while riding around on it. And I haven’t had the chance to ride it around and try to troubleshoot the issue because by the time it has acted up both times we are beyond exhausted and just ready to head home. Other than this it will scream like a champ for the first 2-3 hours. I would like to know what I’m getting myself into. Is this something that’s common and a simple fix or should I run for the hills? I have access to it on a daily basis so I can check things out if you guys have any suggestions. I really appreciate the help and I look forward to getting into jet skis and the Seadoo community.
